I purchased this turbo last night and today I scoured all 43 pages of this thread and took notes to summarize the issues I’ll encounter. I had a few questions after reviewing all of the great material here in this thread.
1.
One question I don’t feel was answered completely has to do with the turbo elbow, the stock one being insufficient. I’ve found some downpipes with elbows with split waste gate ports and I’ve found simple supposedly larger elbows. What is necessary here to avoid the turbulence that could cause waste gate chatter or compressor surge? Will a larger elbow be enough, because it seems like the same problem would exist with the stock elbow as an aftermarket one since the waste gate port is still dumping into the same area?
2.
Someone had noted that the Bolt size for the downpipe was incorrect (was 10x1.25mm, should be 12x1.25mm)
Did you just center it and torque it down? What was the fix here? It reads as if the bolts were smaller on the turbo than the holes on your average MK3 downpipes.
1.
2.
