IwantMKIII;1538337 said:
April 21? Unacceptable. Move it up
want to sponsor my dyno time? looking more like 24th now (weekend, because i work mon-fri)
UPDATE: booking confirmed for the 21st of april, pick up 22nd. im hoping to get it tuned for all the map the internal 2.5bar sensor can read. 3 weeks time and i will have a result, im hoping i have no other issues (like clutch, fuel supply ignition etc)
ill post a power run graph up when done.
Here are my mods
Fully rebuilt 7mgte
Arp main cap bolts & rodbolts
new cast pistons
shot peen'd stock rods
balanced incl flywheel & pressure plate
BC valve springs
3 angle valve grind
cometic MLS headgasket & arp studs
exedy HD button clutch
drilled out Jpipe
835cc injectors
walbro 255LPH fuel pump
3" turbo back exhaust with 1 straight through muffler
600x300x100 FMIC
Haltech E6X Standalone ECU
2.5bar map sensor (inbuilt)
and obviously the T61 turbo listed here
Should have the goods for some respectable power and give a good indication for other people wanting to follow this path
UPDATE: just over a week to go
cars driving nicely on the haltech, ive been working on the base tune and the last few issues ive had, it hasn't seen boost yet and it wont till i hand the keys to the tuner, All thats left to fix is the dash temp gauge and oil pressure gauge!
It's getting tuned on a Dynapac as well not a roller dyno.
