IJ.;1468008 said:An EBC will help the spool situation with an IG Turbo as well guys.
Justin727;1473206 said:That turbo has nothing to do with this thread...
speedgilligan;1473281 said:Except it does cause its made by the same company....
7Matt-GE;1472694 said:http://cgi.ebay.com/ebaymotors/T76-...r_Truck_Parts_Accessories?hash=item27ad603120 <---- this is the turbo im gunna do for my NA/T build i will definitely get back to you guys if this issue isnt resolved. it seems like these guys are reputable on paper.
carter;1474037 said::3d_frown:
Anything new with the turbo?
paradox616;1474538 said:i've put 1500km on it so far, but i'm running 5psi until i fit my new engine management, seems very happy doing what its doing, i cranked the gain all the way up and it spools nicely now any higher than 5psi on a cold night will trigger fuel cut. however on a warm day i can run 7psi. must be something to do with the density of the air.
So the bottom line, if you run this on a stock ecu/afm @psi you will hit fuel cut.
bountykilla0118;1476069 said:When are you looking to do the engine management? How does it pull compared to the ct26 at 5-7psi?
IJ.;1474547 said:Makes sense you're flowing more volume with cold dense air.
87witmoreboost;1478216 said:Noooo, you're flowing more MASS.
IJ.;1476906 said:Best pump fuel available here is your 93.
