Done with the first event for the year.It was very cold ,and to make it even worse my ABS stopped working early in the morning. Here are a 2 pictures that someone took when I was "breaking"
honestabe;1840970 said:How streetable do you think that alignment is? I want something that will make my car handle really well but not make it unbearable to drive on the streets. Do you think that it is safe to go without the sway bars on a street car if you have a similar suspension setup like yours?
spiller;1841001 said:How many miles did you get out of those heims LD? I gather this doesnt get driven on the street? I have all of the wes arms ready to go in (as you know) but im reluctant to use the car on the street at all due to what I see above. Also have you solid mounted your front and rear subframes or are you using poly?
spiller;1841028 said:I would have thought the street use would increase the wear with all of the drains and potholes you encounter as opposed to a smooth race track. What is the comfort like on the street? Also you didnt answer my subframe question. Im interested to know what solid subframes feel like on the street too (im assuming yours are solid mounted)?
spiller;1841036 said:That's interesting, where did you get the nylon spacers from? Custom made?
I have some alloy ones here that wes machined up for me but im not sure I want to use them. I dont think the supra really suffers from a lack of roll centre correction in the same way that say Nissan S13s and R32s do but the factory rubber subframe spacers are no good for the track IMO.
I asked John Smith about his subframe arrangement and he said they were "braced and mounted solid" although nylon/poly spacers could = solid in some people's opinions.
Do your homologation papers speak of any bracing in the front subframe?
spiller;1842510 said:Is that braided PS hose the same one from driftmotion?
planemos;1842526 said:Going electic ps would be sweet. I think some new Toyotas have it on the steering column.
LordDigital;1842517 said:Yeap ,this is DM PS hose. Plan for the future is ,as soon as my PS pump goes again to get rid of it and setup MR2 Spyder hydro/electric pump. A buddy of mine got a controller/emulator ,which means that the power steering amplification can be controlled from the speed sensors or/and Potentiometer. The MR2 Spyder Pump can also be moved further down and much further back![]()
LordDigital;1842550 said:I did not know that Toyota has the electric on the steering column setup.I've seen some "race" cars using the Chevy Cobalt electric steering column which is uber cheap ($60 or so on Ebay) ,but I will be somehow afraid to modify the steering my steering column...
