It was a weird experince today at CHI2K12 Dyno day. 3 Supras all Dynoed above 1000HP (One reaching 1300 IIRC) and I was next...
Was not shooting for too much horse power ,I know that turbo is cable of 600 at the wheels but I would never push that much on 1JZ ECU ,and the USDM 550 could not support more than 550 at the crank anyways - so my goal was 500whp.
My first surprise was that the car spun quite a lot on the first run. 10 secons later I realized that even tough this is suppose to be one of the best tuning shop for supras in North America ,they probably never dynoed Supra with so much negative camber in the rear
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
2 guyz later and the problem was "solved"
Then I got my first run ,boost was 12.5psi with AFRs from 10.9 to 11.5 resulting in 455whp.
Finally I got my biggest surprise of the day ,on 15.5psi car made pretty much the same power(458whp). It is true that the power look great ,but I wonder what can could be the cause of max power at around 5200rpm which is the same RPM and power figures for 12 and 15 psi...
