eraezer;1767784 said:which IC are you using? or what's the measurements of it?
spiller;1791270 said:Great thread, cant believe I didnt see this earlier. Do you drive this car on the street dude? Pretty nuts if you do haha.
1000lbs is pretty firm but I dont mind a harsher ride also, puts hair on your chest! What do the cops say about a full cage when they see it, or arent they big on that in IL? I'm in Aus most of the time but spend about a month in Chicago each year as my fiancée is originally from there but it'd be great to catch up and go for a ride/pick your brain/swap ideas as i'm building my supra for the exact same purpose currently!LordDigital;1791518 said:It may sound weird but after the build this car saw a lot more steet miles than track miles. Last year I trailed only once ,since I'm too lazy to wire by red 4runnerFront springs are rated at around 1000lb/in and the ride is not too harsh ,compared to my CRX with 700lb/in and SPSS3 valving the ride is actually pretty good ! I should give you a ride if you are in Chicago area
destrux;1791598 said:Your car is the only car other than mine that I've ever seen a forward slanted FMIC on.
Mines a center in/out though, and I have a smaller core cause I sized my system for 400hp max.
spiller;1791611 said:1000lbs is pretty firm but I dont mind a harsher ride also, puts hair on your chest! What do the cops say about a full cage when they see it, or arent they big on that in IL? I'm in Aus most of the time but spend about a month in Chicago each year as my fiancée is originally from there but it'd be great to catch up and go for a ride/pick your brain/swap ideas as i'm building my supra for the exact same purpose currently!
Do you by any chance have any other pics of your modified rear subframe? It looks like its had box sections welded into the front diff mounts and also X bracing, anything else there? I am pulling mine out soon to fit the beech arms but wanted to have my fabricator strengthen it before hand so ideas would be great!
Also how is your brake pedal feel with that larger MC?
cheers
Simon
Dylan JZ;1791622 said:Mine is slanted as well, but it's regular size 24x12x3.. We did it that way because the stock unit was positioned the same.
