Damn that sucks Alex. Luckily it looks like it was not too bad, but that is a fast corner on that track. I really wish that track had proper run off and walls instead of trees. There are some places where if you go off you will be hitting large trees, which is not good.
I'm not sure if you know this but MCSCC kicked me and a few of my friends out for the year over some major BS so we won't be back this year, and maybe ever again. It sucks because I was looking forward to running with you some more.
Also I wanted to point out I saw you switched down to 3rd gear in the carousel, I think you will find this is faster once you figure out exactly when and how much throttle to feed in as you are exiting. The car is on the edge but very manageable, at least in my mk4. In the high speed left hander where the crash happened, after watching my in car after my last event and analyzing it to prepare for my next event (which I got kicked out and can't do...) I think the fastest way through that corner is a really late turn in with a slightly slower entry (late apex), and then hug the inside of the corner curbing and track out to about mid track at exit being under close to full throttle the whole time. I noticed as I went faster and faster that my car did similar things to what yours did during the crash and wanted to push wide at the exit. I had a slight 4th gear slide going on in 2 of my slower runs at my last event right there due to this.
