Progress!
Got sick of doing school work so I went to the garage for a few hours. I installed a few new hoses and cleaned a few others. Installed a new CPS cover/bolts, and the knock sensors from my old engine. Changed out the destroyed transmission mount for one in better shape. Also put on the manifold spacer that I had a new stud welded to yesterday. Then I figured I would finally install something shiny. The IC seemed like a good choice so it is now in place. Had to cut the car a bit to make it fit where I wanted it but I am happy with the outcome.
I also picked up 6 feet of 1" x 1/8" Aluminum flat bar. This is the material I will use to mount the fan to the rad. Polish it up and it should look decent and I hope it will work well.
Fills the bumper nicely. Always wanted a nice front mount.
Lots of room left for an oil cooler and possibly a power steering cooler. Not sure if I need a power steering cooler...
This spacer moves the turbo up and forward while also rotating it a bit. Leaves it in a nice position. It's also a good place to store the extra nuts. lol
Bought a new cover from Toyota. It's pretty.
Transmission mount from my old transmission. It was in 20 times better shape than what came with my new setup. Should probably get a new one but my pockets aren't that deep.
This is under the FFIM. Replaced the knock sensors with the ones from my old engine. This new setup had a code 52 problem. I figured this was a good plan since I know my car wasn't throwing a code. I will do the rewire and worry no more.
New 90 degree hose on the back of the head. I had to change it at an auto-x event once...never again. I also considered the new Mushimoto hose sets to replace the heater hoses. They look great but again, not made of money. Maybe in a year or so once the girlfriend is off my back about all this spending. lol
Here is the new rad, fan and hopefully the mounting hardware.
