Progress!
This time with pretty pictures. lol
I spent about 2 hours last night thinking about gauge placement and how much I dislike how every single one of my gauges is different. Since I am not rich I have decided to use the ones I have instead of replacing them to make them match.
This is the bezel I made from stainless steel overlaid with carbon fiber. The sheet meal already had the carbon fiber on it...not my choice. Turned out ok. Now just need to cut the back out and secure the bezel in place. I wanted the gauges sunk into the pocket but the faces are too big. Even with the 52mm gauges.
This will have to do.
Measured the opening and cut the panel to be ~5 mm bigger in every dimension.
Steel backed.
Mocked up seeing how it would look.
Almost finished. Just needed a trim to make them fit flush without distorting the stereo surround into the climate control space. I have since trimmed it and it fits perfectly.
Now all that's left is to mount the AEM wideband gauge and I'd like to add a pyrometer. When I do I think I will buy the pyrometer to match the oil pressure and move the water temp to the pillar pod with the wideband. Or I suck it up and buy a new oil pressure gauge so they all match. I have looked and can't find anywhere that you can buy just the gauge faces.
I also picked the spot for my boost controller. I wish it was the black one but this will work. This might also be the first time I have shown my new steering wheel. It fits the direction I want to take the car in. More classy, less teenager.
