Rennats Rebuild Thread
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
update time!
bearings - done
crank - done
pistons - rings gapped and in!
head studs are in
block is painted shiny black
oil pump is in - clearances where checked it was on the low(tight side) for all of them!
need to order:
3mm HKS head gasket
DM oil pump hose
various parts
maybe some other DM SS hoses
hopefully a 3'' and a blitz exhaust if i have enough money left over at the end of next month!
and im getting jaw surgery on june 9th. so im hoping to get most of the major work done before then, seeing how im going to have my mouth wired shut!
PICS tomorrow! tired...
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
IJ.;1027368 said:
Rings all the right way up?
i looked for markings on the rings, because i know they are suppose to go a certain way... but there was NOTHING that was screaming "put me up"...
the last set of piston rings i did, they had to go a certain way... but these were different... just flat sides, and flat edges. Its whatever probe sells with there pistons i guess. there were no instructions for the rings either.
Chamfers on edges or dots?
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
They're NPR rings if that makes a difference.
Edit: I just took a look at these rings and there is a dot. On the same side marked N100.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
there already in...
and i looked at every single ring, there was absolutely NO marks on either side.
and there were no instructions with the rings either... just chillin in the box.
unless who i bought them from switched out the rings, which i'll go look back through the pics, but im pretty sure they were the ones meant for this car. lol
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
I have a set of probes sitting on the shelf.
With the dish volume, i'm taking my time thinking if i'm going to use them or not.
I think I, probably got the second batch or first batch.
I know a few sets have total seals and the others have NPR's.
If that helps. But if they're in they're in!
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
its what i assumed...
zum, could you take pics of your rings? because i have a picture of mine in the clear plastic wrap stuff, and i wouldnt mind comparing... i might even have the little bags too..
the whole assembly turns smooth as butter. i find it to be rather amazing.
i ordered my head gasket, so that should be here soon enough.
IJ - first off, are you still on the stock oil pump system? i've been debating between using the OEM metal hose, or getting the DM oil pump hose... what are you thoughts on this?
92nsx
2,957
Clearwater, MN
Your build looks just like mine. Same pistions, rods, timing belt, ect. You go new OEM pump, shimed 7mm, driftmotion oil hose thing, like mine also??? Did you find my photobucket????? JK, I'm still wating on my head to get back form the shop. I'm having it rebuilt with all the goods; port polish, BC stage 3 cams, springs and 1mm larger valves. Even my cam covers are power coated black like yours. LOL You engine is looking good, way to go. Great minds think a like. P.S. thank you for the DP.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
still using the OEM pump... all of the clearances were still on the OEM low side, so i said why bother... although i did shim it 5mm. as 5mm puts you right at where you want to be, 7mm just makes it a little higher...
thinking of either going with the driftmotion oil hose or just using the OEM line... im going to measure how wide the oem pump is first, because if that AN isnt any bigger, theres no sense in investing in a smaller "shiny" hose...
no powdercoat, just bbq paint. haha.
and i found no need to do all of that head stuff as im shooting for 400-500hp and the OEM head can easily do that...
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
Rennat;1029224 said:
there already in...
what rings you got are the ones that i received with the kit DM send me...There are alot of rings that go either way..atleast chryslers that i work on have rings like that...My NPR's came with numbers on one side so i put them facing up as per TRSM...
