beater = no go, i dont really enjoy having two cars, i enjoy getting very comfortable with just one.
DONE - Install driveshaft
Bleed clutch
DONE - hook up wire harness to the inside, and also connect up the rest of the stuff
DONE - back heater return hose (i totally forgot about it)
AFM and power steering res need to be put on.
attack power cables and make some custom ground cables so i can ground everything. i already made one for the coilpack.
wire up e-fan
DONE - order lower shifter bushing from either DM or local yota dealer
put oil, coolant, trans, power steering fluid in
DONE install radiator
DONE - tighten motor mounts
that that lower IC pipe is a mother fucker, especially since i didnt see how it was suppose to go before you take it off (had a friend helping out) so that was pretty funny to do. the back heater hose was easy with the 8mm socket and a 2ft extension. hahaha. driveshaft was a bitch, pretty sure i need a new center bearing (which im pissed about, but shaftmasters 2pc or 1pc here i come!!!)
gonna go buy some more new hoseing to run new oil cooler lines, and that p/s line from the res.
alt relocation you ask? why not! lol. when i bought it, along with the SS clutch line, i had intentions of going FFIM later... so i was like, hell, why not just grab up one of those brackets and move it lower, plus i like not having it up high, looks funny to me...
whats left:
Find o2 sensor connector (no idea where it is!!!)
AFM wire up and clamp down.
p/s res. clamp down
e-fan wires
starter cable and some other cables
upper IC pipe clamps
fluids
make sure i have gas! hahahaha
and lots of other little things that need to be connected and made!
now im off to my orthodontist for a check up cause of my surgery!
Bleed clutch
wire up e-fan
whats left:
p/s res. clamp down
e-fan wires
fluids
