Rakkasan's rebirth
Status
Not open for further replies.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Ok thanks. Good stuff. It came out really good. I was hoping I would get that answer. Lol. I'm putting my supra in a warehouse for a little while to work on it. Take the engine out, finish the interior, fix dents, paint it, build a new engine, etc.... But your supra is lookin really good right now. Keep us posted. I'll be watchin....:bigthumb:
rakkasan
Currahee!!
Fort Campbell, KY
siman said:
Wow Rakkasan! Your doing a mighty fine job there!
-Jonathan
Thanks for the kind words, Jonathan. There's a real strong chance that I'll be moving back to Tennessee within the next few months, in the small town of Philadelphia (just south of Loudon and or Knoxville). My sister-in-law graduated from MTSU & I was stationed at Ft Campbell for many years, so I know TN like the back of my hand. We'll have to hook up....
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
You are going to die when you see that manifold. Pictures are great, but hold it and check out and you will definitly be floored. I can already see you rolling around on the floor with it :icon_bigg Can't wait for the final product.
polobai
Orlampa
thanks mark-will stop by one of these days, but dam your so far! gimme a ring if you pass by orlando at any time. nice work by the way!
rakkasan
Currahee!!
Fort Campbell, KY
Will do. Isn't there a meet scheduled soon?
You got a short runner too, right? I've stared at the pictures of ever since Ron put them up. I haven't had time for porn (I haven't needed it, either). :biglaugh:
polobai
Orlampa
dunno if a meet is scheduled soon-but my car is down for a while anyways-doing some upgrades-ffi+gt4082+maf pro=fun!
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
rakkasan said:
As expected, no motor, still waiting. Oh well, I still have some busy work to do.....
rakkasan said:
How cute. You might as well give up, I'll own your ass regardless. :biglaugh:
HAHAHA!!!!!!!!!!! Hey, how much would you polish my ffi long runner for?
rakkasan
Currahee!!
Fort Campbell, KY
Reign_Maker said:
you do that by hand? What grits do you use? compounds?
First let me preface by saying the runners on the intake are a major pain in the ass. Use a palm sander as much as possible.
No matter how smooth the piece of aluminum I'm working is, I always start with 80 grit. Sand it w/ 80 grit until you think you've removed all the high spots, then hit it again for another good bit. IMO, the first round of sanding is the most crucial. If you miss something in the early stages, you won't get rid of it in the latter stages.
After the 80 grit, hit it with 220, 400, 800, 1000 & then 1500. Once you've gone over it with the 800, you should be able to start seeing a luster coming through. If you see something that you missed, drop down 2 grits (ie. If you're using 1000, go back to 400) & hit it again. Don't be afraid to sand, sand the shit out it.
Get a good & powerful bench grinder & put a cotton buffing wheel on each side. One will work, but two is the ticket.
Put a small amount on the part you want to buff, keeping the working area to about a 6-12 sq inch area. Doing a larger area will cause more problems than it's worth. Anyway buff the area nice & slow. Also, use light pressure, don't push the piece into the buffer. You'll more than likely cake your paste while buffing which will cause your buffer to 'grab' your piece & it will sort of bounce. If so, back the pressure off a little until your buffing nice & smooth.
Once your done with the small area, take a clean rag & remove the paste. For the areas that the paste caked, take some clean paste & rub over it. That will release the cake. A spray wax will do the job a little better. Also, you'll see the areas that the paste caked, they'll have a yellow tint to them as if it was heated a little too much (look close at my pictures & look at the runners, you'll see what I'm talking about). For those areas, take some 1500 grit & sand the color out. It won't take much effort. Remember, get everything off before buffing the area again. Clean between each buffing, and keep your hands as clean as possible too.
You shouldn't have to buff the piece more than three times, but keep going to suit your preference.
Now, for the runners of you intake and the likes. You'll notice that there is a lot of valleys that are hard to get to. Also, the casting is very rough. & used a lot of the little drum sanders & other assorted bits on my Dremel to get the runners as smooth as possible. Once I exhausted the Dremel effort, I started sanding by hand. It's an assload of work, but it isn't too bad. I need to hit my runners some more, but I think I can knock them out in two or three more hours, bringing my total to 6-7 hours.
Status
