p5150 said:
FIGGIE YOUR 7M DIED???? You user errorer........
infact it was
.. incase you missed it, over revved in a patch of ice
Though at least you are paying attention now.
p5150 said:
Sorry guys - this isnt opinion, its fact. The 7m is more prone to oiling issues than the 2jz. Period. End of story.
sorry slick. Apparently you don't understand what facts are. Unlike opinions, facts are NOT debatable regardless of what you think
The 7m ONLY oiling "issue" is the oil cooler design. The oiling system without that one part is actually very ingenious and reliable.
p5150 said:
Duane's 7m is built. Was it not when he ran the TDO6? Isnt that the whole point of this?
BIG NEGATIVE
up to that point he did not open the engine up. After he left the TD06, THEN came the upgrade along with everything else.
p5150 said:
The rods are more stout in a 2jz. Its just better designed. Toyota didnt regress - give it a rest dude.
hmm
reading comprehension 101?
Since when is head bolts rod bolts? Are you sure that you graduated High school with a reading comprehension which equals that of a pre-schooler?
p5150 said:
Are you aware that thats irrelivant? Whats a bigger head bolt or stud going to do for me? Should I put in bigger rod bolts too? TT users have put down 900+ on a stock 2JZGTE and they use the SAME bolts. The head didnt blow off.......
really?
seems like Ryan Woon, Titan Motorsports, Sound Performance, AAP all disagre with you and it is VERY relevant
here let me get you, your tricycle so you can backpedal some more. and also since we know that 1/2" bolts hold 1000+ hp without problems. 12mm > 10mm
p5150 said:
Nope, always had enough oil. It was ENGINEER error for not putting oil channels on the cam saddles. I have taken apart at least 15 different 7M heads unrelated to myself and ALL OF THEM HAD SOME SORT OF SCORING. Sorry dude - I dont believe you. If it is all "user error" then why cant you find any threads in the MKIV world about it? Eh?
AHHHHAHAHAHAHA
HAHAHAHAH
Engineer error... HAHAHAHAH.. No. Ignorance of how to take care of an engine does not mean the engine had the problem.
Fact, cams that are scored are caused by low oil condition in ALL CASES. What this means is that you were not checking your oil and this in the end means USER ERROR, again! see how easy it is to connect the dots?
p5150 said:
Perhaps you could see how much money he spent to do that? Did you note that he used STOCK 2jz valves.
I know exactly how much he spent to do that.
p5150 said:
How the hell do you know this? Besides - we are discussing MODS we are talking about the capabilities of a STOCK block with MINIMAL mods like a MHG.
simple
perhaps you heard of it. machine measures CFM flows at different valve openings
even some of the MKIV guys came in on that one thread
here is a hint. The stock MKIV head flows roughly 220 cfm per intake runner give or take 5 cfm.
p5150 said:
Mibrum has a totally NOT STOCK 7M
Adjuster has a NOT STOCK 7M
And you have a NOT STOCK 7M
How much did you pay?
I can wrap my 3vze in my truck that high too - it doesnt mean its going to last as long. Shorter stroke means more reliable components at the upper rev limit. Physics dude. Piston speed is directly related to stroke length.
haha
which apparently you have none of. Piston velocity is not the ultimate determining factor of rev. If it was, the HKS 3.4L storker 2jz folk would not be spinning to 9.5k rpm
which mind you is only 3mm smaller stroke than my and adjuster's stroked engine.
as for stock, no one that runs a stock 7m is going to lay down 1.2k for an AEM (and personally they could not give me one to use in my car).
As for $,
well to give you an idea, here are a couple of parts for you to crunch
Motec M800 w/ adv features, and wideband single Channel enable.
Motec CDI-8
and that is just a TINY parts list that I have (and that I posted on here), I do not cut corners as my time is way to much money. I do it right the FIRST time.
