Project Git 'er done!: Stages 1, 2…now 3.
1986.5supra_kid
Rice? No its Corn (E85)
So a little update; more like, 1 step forward, 8 steps back...
Ever since I rebuilt the engine back in 2012, I've always had an issue with oil burning. I thought that maybe it was a drain backup on the turbo, so I bought a better one- no luck. Then I thought, maybe I idled it too much, without putting a proper load on it, causing a poor seating of the rings. Perhaps it is. But I also thought that maybe it was that I didn't seat the valve stem seals in place properly, so recently, I tried replacing those with the head in the car, since I also had a new pair of BC cams and springs to install. After putting it all together, she still burned oil, and made the usual smoke screen. So a few months ago, I decided to pull the head, and check the head gasket, because after using a borescope, it seemed that there was a trail of burned oil coming from the mating surface on most of the cylinders.
Well, after pulling the machined, 0-mile head, I measure it and discovered that although the mating surface was dead-straight, the cam surface was .025" warped. Basically 3 times the limit. Apparently when I sent it to the shop, they decked it without ever checking it for straightness. So.... after finding a good used head, I sent it to the machine shop to have it checked, and got a three-angle valve job. I ordered a fresh set of valves for it from an online seller, but when I tried to install them, I found that most of them were going to require a shim thickness of 3.3-4.2mm!! WAY over the norm. Looking at the valves more closely, I finally realized none of them were fully seating; They're oversize valves; .5mm larger than stock, lol.
SO....I took the head to a different shop, had them cut the seats to accommodate the new valves, and ordered a fresh 2mm head gasket.
Finally time to reinstall the head, right?
Well, just before I tried to lay the head back on the block, I decided to reach down and verify that the oil pump driveshaft wasn't doing anything weird, since a number of people on FB lately have had issues there... Sure enough, my driveshaft pulley moves in and out by over 3mm. So now, the entire block has to come back out, to check for oil pump/ driveshaft damage, and do the necessary upgrades. So this weekend, I'll be pulling the motor and starting a full tear-down of the zero-mile block. I'll post pics soon, wish me luck.
Wishing you luck!!! I'm surprised you are still hard at this <3
Also do you remember how the trunk release cables go?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
So, for those 4 or 5 of you that still get nostalgic and peruse the build gallery, here's an update.
I've finally completed the rebuild of the brand new, 10 yr old engine, lol.
I don't have too much in the way of pics, but the rundown is:
All new clevite bearings, new Wiseco piston rings, new cometic head gasket.
Fully rebuilt head with oversized stainless valves, BC 264 cams, BC springs,
Rebuilt oil pump driveshaft with newly fabricated collar, SR Fab needle bearing retainer.
Hopefully, this will address the oil burning and reliability issues moving forward. I've reinstalled the engine,
and I switched back to oem 440cc injector and the oem afm as well, in order to build a base map for the DET3.
I also found that I had a couple of incorrect connections between the DET3 and the ecu, so I'm not even certain why it used to run, lol. Anyway, the car DOES run, but since it can't be driven, I've only run it for a few minutes, to confirm no leaks, etc.
I'll wait till after the car goes for body work, before I try to seat the rings.
I also dropped a borescope camera down into the fuel tank, to see whats happened over the last decade of sitting. Still
absolutely spotless. I was very relieved to see that, seeing as a couple of gallons of standard super unleaded blend has just been sitting in there since Obama was in office.
I also replaced the stock(brand new) rear brakes with the Poor man mods LS430 setup. Looks a bit more proper, behid the 18" wheels. I also replaced the hatch struts, since they were struggling a bit. Next step is to finish the final fitting of the carpet, then install the center console and the seats. Then reinstall the quarter windows, then the hatch area plastics.
Included are just a couple of random pics.
Pabblo83
I recently ordered a fresh set of valves for my engine from an online seller, but when I tried to install them, I realized most of them required a shim thickness of 3.3-4.2mm—far above the norm. Upon closer inspection, I discovered the issue: the valves were oversize, .5mm larger than stock, which prevented them from seating properly. To resolve this, I took the head to a different shop to have the seats cut to accommodate the new valves and ordered a fresh 2mm head gasket. This experience emphasizes the importance of high-quality, precision-engineered Supertech valve components, such as those provided by Supertech. Known for their superior valves and valve train components, Supertech serves the racing market with products that meet the demands of every type of racing, from drag racing to rally and road racing. If you ever encounter a situation where standard components don't meet your needs, Supertech is always ready to provide custom solutions tailored to your specific application.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
..."shop to have the seats cut to accommodate the new valves and ordered a fresh 2mm head gasket. This experience emphasizes the importance of high-quality, precision-engineered Supertech valve components, such as those provided by Supertech. Known for their superior valves and valve train components, Supertech serves the racing market with products that meet the demands of every type of racing, from drag racing to rally and road racing. If you ever encounter a situation where standard components don't meet your needs, Supertech is always ready to provide custom solutions tailored to your specific application.
...okay...
