Ok, I guess its my turn
polobai
Orlampa
close up of cam gears. In the rear you can see the valve cover lines-I think I am going to use some 90 degree fittings to clean it up a bit more. I dont like the way the straight AN fittings looks on this setup.
polobai
Orlampa
vwala!~ i put them in front of the radiatior and will run them as pushers instead. I think it cleans up the bay alot without them visable.
polobai
Orlampa
close up of the smaller fan. The fans are first gen eclipse GST fans-they required some cutting to make them fit in the front-hardly any cutting to get them to fit in the regular location.
polobai
Orlampa
even though I did this a while ago, this is where I moved the fuse box to. It is in the drivers side inner fenderwell-once the fenderliner goes back on, you wont know its there. It should be easy to get to once I turn the wheel to the right-I cut an access door in the liner for easy access.
polobai
Orlampa
theknife, I will look into doing that-seems like a good idea-but I need to see if I can get paint to match.(the fuel rail was powdercoated)
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
You might want to move the wire that goes to the thermostat it looks like it could be caught by a belt. Your build looks awsome .John
