the only thing that i whould do since you hid all you stuff in the fender is t eletro geas all the plugs to stop carowtion/bad contack's and such is gets very wet/moist around that area cause there is nto mroe enigne keeping ti dry no more plus cheep insurance
thanks-already doing that with some Di-electric grease, I think its a good idea for all the engine harness plugs so I am going to do it to all. Very cheap insurance.
where I mounted the menthonal injection relay and boost sensor.(right by where I put the fuse box) Here you can also see where I mounted the injection nozzle on the IC pipe-I think it will do better here than right by the throttle body.
In case you dont recongize it, its the big break kit made by ARZ for our cars-quality is second to none-fit perfect with a little cutting of the dust sheild.
