Ok, I guess its my turn
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Damn ray its looking nice cant wait to get my shit rolling again.....Btw im that guy who got the bottem end from junito if you remeber me talked to you at the titan meet about a motor mount.
polobai
Orlampa
thats whats up man, unfortunatly dont have that mount-but get yours going so we can go meet up-hows junito by the way?
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Everythings almost done just waiting on a AC bracket and put everything back together, Right now the cars getting prepped for body work.
Last I herd from Junito he was doing fine but having a problem with a knock sensor on his 1j.
polobai
Orlampa
thats cool-the ac bracket i believe I have if you need-if you get a chance, can you PM me his (junito)#, or tell him to give me a call?
polobai
Orlampa
another: now the specs are-18x9 with a +43 offset in the front, and 18x10 with a +44 offset in the rear. The rims were taken apart, blasted, and then powedercoated gloss black in the centers and then anondized blue for the lips. Then they were put back together with new Volk Racing stickers. Also, the serial number stickers had to be removed, but could not be reordered-I just have them preserved just in case ever needed. To hold them in will be matching blue anodized Rays lug nuts:biglaugh:
polobai
Orlampa
the turbo is finally put back together-had the compressor housing polished and then clear coated for protection, and less maintence.
polobai
Orlampa
the hot side is a .81 a/r Precision backhousing. Thanks to Sean at Titan for sourcing this for me.
polobai
Orlampa
here you can see where I tapped for the EGT probe-I think this will give the most accurate readings from all cylinders.
2jzmk3
Guest
anytime.. damn its coming along nice!!
mine is back home so now i can really get some work done. just a matter of me finishing it up, but im in no rush, plus with the holidays i dont know how much my wife will let me work out in the garage late...
looking forward to see it done ray.
Dec 3, 2003
6,653
Canada
You can't get work done if you are on SM now can you :icon_razz
Good job Ray! Keep the pics coming dude!!
Duane
polobai
Orlampa
Thanks alot guys, your car should be running pretty soon then huh Sean? Duane, yours already is, when are those #'s expected to hit?
polobai
Orlampa
ok, more pics: general mock up with cam gears installed (just anodized purple, and catch can setup
