Nah, I put the Maft-pro there becuase that was the only convienient place to mount it. If you look closely, the unit is actually flush mounted where the ashtray used to be, I cut the console in about 1 inch all the way around. I think the setup came out pretty nice and usable.
i am honestly not sure where you guys are talking about-can you be a little more descriptive? Are you speaking of the coin holder where the tems switch usually is, or the one by the fog lamp switch?
Thanks for the compliments! The things between the shifter and center console lid go like this: MAFT pro, 2 switches (one for electric fans, one for Tems in the rear) then a Nitrous Arming switch, and nitrous momentary switch on orange carbon swith panels. Are any of those what you are speaking of?
Update time-finished door panels. I decided to two tone the panels in a grey and black suede and reinstall the 4 inch component set on the bottom with another 6.5 inch component set in the factory location with the tweeter on the panel.
I got a new battery, it works wonders-easier starting, brighter lights, everything! Only bad part is that after I hooked it up, i had a serious battery drain, so it killed it and now it wont charge up-anyone have a turbostart charger?
