Thank you.soapra;908288 said:If you use the 2jz water neck and 2jz bypass tube, it works!
Yes, a 2JZ water neck with the 1JZ pipe WILL be too short, but not a 2JZ neck and pipe.
suprastanger507mgte;910349 said:Kool. thanks for the reply Jay and Tis. The 2jzge pump looks a little different because it does not have the hole for the mounting of the Crank position sensor.
you got that right,it's deffinatly bed time for this old manLilMissMkIII;911346 said:When you're old, I hear that 9pm feels like 2am
OneJoeZee;911383 said:Wasn't there a 1.5JZ build going on here or something?
