Well i found the culprit to the Power problem. I attached a pic. The wire is broken or somthing. If i move it the power to the car comes and goes. :3d_frown:
Of Course i have created another problem for myself. I am sure i will be able to deal with it tomorrow, but i knew my Tank Was low but i did not realize it was empty i ran it dry basically. Well just means the engine barley had anything to work with before. I got 5 gallons in. But now i can not get the engine to start :3d_frown: boy am i pathetic. It wants to start and just about goes but then it just stalls. I did install the HKS Gauge i have. Don't think i did anything to mess that up though
I put the Constant 12V on a line i found coming from the Hazard light Switch. The Illumination and Ignition i put on the Line coming from the Dimmer. Which i just found out you can not do
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I had the gauge working but did not have the dimmer switch attached. As soon as you light up the Dash the Gauge goes bye, bye ....lol guess i need to find those two lines elsewhere. Its my first gauge install as well. I am such a newbie.
