well I just check my connections, I have the orange wire from the maft going to the yellow (analog 1) of my LC-1 and the purple wire from the maft going to the green (analog ground) of my LC-1
Check it... set to 1 for the LC-1drjonez said:what about settings in the MAFT pro?
pimptrizkit said:for ease, you want to use analog out put 2 and make sue your analog ground is on a good ground.
i had the same problem.
i did notice you could go into the lc-1 and edit the table's to read different but when the power is lost, it resets to factory and you have the same problme. so changing the wiring was just easier for me.
catch2nd said:WOOOT
For all those using the LC-1
You must use analog output 2 as the output for the MaftPro....
-Dustin
tookwik4u89 said:Maft pro FTW!! Bob, is there any possibility of 2 step rev limit being setup in the future?
Snotcycle said:i read all 79 pages tonight, all i can say is wow, im so happy i chose the mk3 supra as my first car to mod. what an amazing community of talented individuals. i very much look forward to having money to get crazy with my 91turbo :icon_bigg :icon_bigg including a maftpro,
Snotcycle said:Question: How much tuning work is required to get near-stock drivability off boost? how bout on boost? I have never played with any aftermarket car electronics except a turbo timer so i may be on here begging for help in a few months if i get one of these super-duper maftpro's
Im just thinking the limp mode is easier to hijack, when i get this bov problem taken care of i will try it out. Also for some reason i data log, then the file doesnt show up to look at like it used to, im sure i will figure it out. Ive been tuning off data logger in wideband, so limited to T/P, A/F, RPM.turbobob said:This is the way I run both my cars,
there is always a lot of debate about "limp" modes when this topic is discussed. My suggestion is to try it and report your findings.
Bob
tookwik4u89 said:4.63 = timing control, it is out. You need to do additional wiring to use it.
turbobob said:... Now, I don't have the XDF, or ADS files ready, but the 4.60 files still work ok for now. ...
