malloynx said:FWIW, the 4.65 software is not working corectly in the MK3
Its not working correctly in YOUR mk-iii
at any rate, tell me what connections you have made? Is timing control connected?
Bob
turbobob said:Its not working correctly in YOUR mk-iii
Bob
atlpd3147 said:i was wondering if someone can chime in on this for me. i have the car running with the maftpro i have some idle studder and my air fuel ratio sweeps from 14ish to 16ish but it does hold at 14ish for several secs then leans out a bit then goes back to the 14 range. anyways i checked my monitor page on the maftpro and the o2 signal reads 2.4v - 2.6v but i checked the aux 1 signal and it reads 0.01 range when the car idling. i read someplace on supramania (if i remember correctly) that the aux 1 signal should be reading the vf signal so if thats true my vf signal is not where it should be. i have the purple wire tapped in the vf signal wire on the engine harness. im running version 4.63 if that helps. i searched aux 1 on this thread and nothing came up.
Vf logging:
-set Aux1 mode to 0
-connect purple wire to Vf
