thats awasome.. cant wait to recive the wires, i'll probaly just order the boost selinod though..
:biggrinbo YESSS, that's great news! Bob are these special wires in any way or can I get some locally? It's not like I'm in a hurry (far from it in fact as I'm about a month away of actually installing my maft pro or any other wire in the car for that matter :icon_frow) . It just seems like a big hassle to have just a couple wires sent all the way to Greece...On the other hand if these are maft pro specific I don't mind putting you in the trouble :evil2:.turbobob said:What I posted is for timing CONTROL. DJ is referring to the timing monitor.
There are a couple wires to add, I can send you a couple.
I am going to try to send out some timing control wires next week, I'll send you some thru DJ, since he has your shipping info.
B
turbobob said:Part Throttle AF tracking using the wideband. I'm still tweaking it, but it works pretty darn well. I unplug my O2 sensors, and let this do the work. I set idle at 14.0, cruise at 14.7, and lean cruise at 16.0......
Aaron or Bob if you can point me out what type of connectors I'm looking for I'm sure that I can get them from a pc hardware shop locally. I did some ebay search here http://search.ebay.com/search/searc...00&fpos=12137&ftrt=1&ftrv=1&saprclo=&saprchi= and maybe you could pin point the necessary connectors there so I could have a visual indication as well.bigaaron said:Those connectors are Molex, any good electronics store should have them or be able to get them. Actually, I have a better idea! If you have an old computer power supply laying around it may have the same connectors on it.
The pins are a little difficult to romove though, so be carefull.
yannis-supras said:Aaron or Bob if you can point me out what type of connectors I'm looking for I'm sure that I can get them from a pc hardware shop locally. I did some ebay search here http://search.ebay.com/search/searc...00&fpos=12137&ftrt=1&ftrv=1&saprclo=&saprchi= and maybe you could pin point the necessary connectors there so I could have a visual indication as well.
Aaron thanks a lot man. Is this all I need then? I might as well buy this very one than drag my lazy ass to a store downtown and look for it :biglaugh:.bigaaron said:Here it is:
http://cgi.ebay.com/ATX-P4-MOLEX-MO...ryZ45342QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They are the same pins used for ATX power supply connectors in your PC. Just go to a computer store and find an ATX extension.
yannis-supras said:Aaron thanks a lot man. Is this all I need then? I might as well buy this very one than drag my lazy ass to a store downtown and look for it :biglaugh:.
bigaaron said:The metal pins will be the correct size, but each little plastic housing is a different shape depending on the number of pins in the connector. To get the pins out of the plastic body use a sharp xacto knife and cut the plastic away. Be carefull not to bend the little metal tabs or they will not snap into the maft pro connector bodies.
IHI-RHC7 said:Most industrial supply stores should carry pin extracters for nearly nothing...
We're so in on the MAft-pro as soon as funds allow.
supralover2000 said:Hey Bob, I can't download the software from the attached link. maybe you can save it on the supramania server so we don't have to join the forum just to get the software upgrade.
