maftpro is working
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
can someone give a readers digest of this whole thread since it's 57 pages long now and should be recreated with out the chatter
drjonez
the motor city
www.4cefed.com
jkbmkiii said:
Ok The pro is up and running , Idles fine untill you hit the gas a little, than it acts like it wants to die????? Its currently set at the directions settings?????
sounds like you've got some wiring wrong or the settings wrong. what are your settings?
jkbmkiii said:
Maft P is saying that my tps= .44 volts released and 3.2 fully pressed, I looked everwhere but how or what is the best way to adjust the TPS , I looked at cygnusx1.net/ But that is not helping
sounds about right to me....any codes?
drjonez
the motor city
www.4cefed.com
appearantly there are some rumors floating about about a MAFT pro v2.....there is NO fact to this. heck, the current MAFT pro has barely been out a year....no major hardware revisions are planned for some time.
note that the MAFT gen 2 will be coming out soon- sorta like a baby MAFT pro. it's just a SAFC type thing....no boost control, no speed/density but it does have the display + keypad.
jkbmkiii
539
Castle Rock colorado
drjonez said:
please list all of your settings, as displayed on the MAFT pro.
All While the car is off but the key is on // the ones listed are the only reading's That Iam currently getting
VE 70
CEL 62
TPS .46
3.12
MP 82.3
MT 79.1
FE 100
ASC 100
CF 100
TAF 11.5
SPK 15.0
BA 82.8
BP 0.1
DC 99.7
jkbmkiii
539
AFL 4
FO 30
VE 70
CEL 62
TPS .46
3.12
MP 82.3
MT 79.1
FE 100
ASC 100
CF 100
TAF 11.5
SPK 15.0
BA 82.8
BP - 0.1
DC 99.7
Running @ idle
VE 53.5
CEL 0
TPS .45
MP 34.2
MT 76.9
FE 100
ASC 100
CF 100
TAF 11.5
SPK 15.0
BA 83.1
BP -7
Codes
24-Intake air temp signal
32- airflow meter/hac sensor
jkbmkiii
539
Vehicle sel: 0
# of Cyl: 6
Displ: 3.0
Airfl source: 0
Map source: 0
Dens Srce: 0
Baro mode: 1
F- out mode: 4
v-out2 mode: 0
Afr sourve 0
F- in mode 0
Aux1 mode 0
elhsupra
Quad Cam Abuser
May 3, 2005
20
TX
Is the brown wire from the 10 pin connector spliced to the Air temp signal (THA) wire going to the ECU? If so, double check the connection.
This may be the cause of the Code 24-Intake air temp signal
turbobob
196
Near Detroit
jkbmkiii said:
System set up ... I set it to 0 in config mode
Ok, with V out1 mode = 0
and the V out 1 setpoint = 2.500 then you should have 2.5 volts on the brown wire (10 pin harness) all the time which feeds the ECU.
V out 2 setpoint should be 3.6 volts for the HAC sensor.
Are you setting stored codes, or are you seeing the Check Engine light turn on?
B
