low oil pressure
Turbo Habanero
4,229
Tucson,AZ
So i just read all 14 pages. And i decided i want my time back lol just kidding.
Atleast you didn't lose to that mustang and fuck your car up that would have been a swift kick in the :kickinthenuts:
Mustangs are like tampons every pussy's got one :biglaugh:
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
Yeah really... my buddy was there and he has a 6 cyl mustang and he was like "FUCKKKKK.... Brian has a faster car than me...." he always thought his 6cyl 01 pony was the best cause he has a nice custom exhaust bullit wheels and bored out his throttle body.....
Anyways my timing belt is fucked.... and it was mint a couple weeks ago after doing a valve adjustment. Does this happen if you don't put it on exactly straight?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
When you had the block machined, did you have the rear timing cover machined with it? If not that could definitely happen, not to mention it could explain your head gasket sealing issues.
jdub
Feb 10, 2006
10,730
Valley of the Sun
IJ.;1406041 said:
What is the crap on the pickup?
(ie: what material is it Aluminium, steel,organic?)
I'd like to know the answer to this ^^^ as well.
If you pull the pistons, that makes a re-ring and cylinder hone mandatory. Check all crank clearances, including thrust washers.
That timing belt explains the noise you were hearing ;)
You either somehow installed the crank timing belt drive gear backwards or the washer attached (straked) to it came loose. You should always retension the timing belt after 500 miles or so.
Not machining the top of the rear timing plate with the block will not cause the belt to do that, but it will cause a HG not to seal.
Some advice: Slow down and do things faster ;)
Bri7man
Jul 17, 2009
580
Torrance, CA
I'm sorry I didn't see your post earlier. It looks to be aluminum since its very shiny/malleable and curly.
I machined the head/block with the rear timing. I did forget to fipg the front of the block though.
I decided to slow down and replace things that needed replacing the first time. I'm doing things right this time. It's kind of difficult not having a engine stand.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Did you flush the block/head oil passages out after they were machined and before putting the head back on?
No FPIG on the top of the timing cover = oil leak ;)
Bri7man
Jul 17, 2009
580
Torrance, CA
Yeah for like the 2 days I was waiting on parts after I got it back I ran a air compressor all over and inside before going to bed. There wasn't much debree and nothing to scale like the shavings in my oil pan/ pump pickup.
I also changed oil and filters 3 times from then. (2 months ago)
I set my engine back down and am taking the head off today then gonna roll my bottom end on some boards/towels and measure per tsrm.
Bri7man
Jul 17, 2009
580
Torrance, CA
Well my oil pump was well in spec although the strainer mesh was bent very close to the oil intake pipe and interlaced with metal shavings in that area possibly from shavings I didn't pick up from back when I got my engine machined.
Anyways that is my theory.
Rods have side play although not up/down.
Apparently I don't have plastigage so I'll be getting that and measuring if there was any main bearing damage hopefully tomorrow.
jdub
Feb 10, 2006
10,730
Valley of the Sun
While you have the pump out, shim the relief valve with washers...about 5mm thickness worth.
Bri7man
Jul 17, 2009
580
Torrance, CA
Ohhhhh Zumtizz just told me to do the same thing. Just throw a 5mm washer in there?
jdub
Feb 10, 2006
10,730
Valley of the Sun
The washers have to fit under the valve bolt...5mm (+/-) is the thickness...you'll need several.
Bri7man
Jul 17, 2009
580
Torrance, CA
Rod bearing clearances:
1).040
2).038
3).038
4).039
5).038
6).039
My theory is the shavings that were clogging the already pushed in mesh on my oil pump was the cause for the low oil pressure.
northwestsupra
1,166
Washington, Marysville
CyFi6;1407752 said:
The washers put more tension on the spring, which holds the valve from relieving pressure until it reaches a higher pressure
sorry, not trying to jack the thread, just really curious. but whats the reason for wanting this. just to have a higher oil pressure? better cooling and lubrication i guess?
