low oil pressure
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
jdub;1409831 said:
It's best to use the stock pressure sender location. For a temp sensor, a T on the return line to the block is fine.
Keep something in mind about shimming the filter relief valve for the cooler: Higher pressure is required for oil to flow through the cooler circuit...this means you will have higher oil temps as a result. It rapidly becomes self defeating.
Thanks Jdub, now I know what I'm in for when I decide to do a t stat sys.
yeah I can see how shimming the filter relief is bad now... I'll just shim the pump relief then.
