Ugh all this sanding sucks, still alot of work left before the parts are all prepped...
I took a break from that today and worked on some other things
My vacuum hoses are all done, my TPS is adjusted and the TB is installed... minus the long bolt which I still need to find / replace.
Removed the stock fuel pump relay and resistor.
Installed my IAT sensor into my "3000" pipe which I got back from ETS today:
It looks like I won't have to pull anything other than the coilpack to get to my spark plugs
And maybe the linkage...
And I played with Tuner Pro a bit
The engines not even running yet and I'm already hitting 0.3 psi of boost :biglaugh:
I also did some other small things here and there that I forgot, such as installing my new CPS cover...
I was originally hoping to have it running by the end of this month, but I have a feeling the paint job will push me back abit further...
