How Much Did You Spend?
bigaaron
4,692
Pomona, CA
www.driftmotion.com
The Reaper said:
jesus!!!!! you guys just DUMP money
Shell - 500
1JEngine Set - 1938
Emanage - 290
e-01 - 220
turbo timer - 90
BIC mounts - 175
hydro fan ecu - 70
muffler - 50
usb cable for shielded wires - 10
PS line custom - 50
Drive shaft - 80
3" Exhaust Piping - 60
Battery Relocation kit - 70
exhaust flanges - 17
BOV - 50
only $3748 total
You need to at least get your engine in the car before you can honestly say how much it cost you total. :biglaugh:
I'm sure I have over $20,000 into my 88 Supra.
Here's how I spent it:
Engine:
Ross forged pistons, .029” oversize $850
Align bored mains and cylinders
Fully balanced rotating assembly
Shotpeened stock rods $1500 in engine machine work total
ARP main studs $139
ARP rod bolts $55
ARP head studs $119
HKS 2mm bead mhg $220
Clevite 77 bearings $125
Garrett GT4082 turbo $750
Precision .82 a/r exhaust housing on turbo $200
50mm wastegate (HKS Race wg copy) $169
Open dump tube on wg
7/16 Exhaust manifold stud upgrade $65
Turbonetics cast exhaust manifold $450
Custom v-band downpipe and 3” exhaust ~$125
4” intake with stainless filter $60
8.5mm custom plug wire set $60
Relocated stock coilpack
NGK BKR6E plugs
550cc Denso injectors from RX7 TurboII $325
Aeromotive AFPR kit $250
Oil Catch can $30
Custom 2.5” IC piping $165
Spearco replica intercooler $220
External oil cooler and filter relocation $300
Relocated aluminum ps reservoir $80
Custom aluminum coolant reservoir $60
7m-ge valve covers powdercoated black $100
7m-ge thermostat housing
Custom throttle cable $25
Samco radiator hoses $105
New engine wire harness $525
Silicone vacuum lines $40
Walbro 255lph fuel pump $105
Billet CPS cap from ARZ $50
Electronics:
EMS Stinger standalone ecu w/pnp harness and wideband $1300
Zeitronix ZT-2 wideband $279
Autometer boost gauge $60
Greddy Type S boost control $330
Mini ITX car pc with datalogging from ZT-2 and Maft Pro, dvd, cd,
wi-fi, gps, Roadrunner front-end, touchscreen 7” widescreen monitor,
Creative Audigy USB sound, volume control and touch pad in center console,
VIA M10000 motherboard, 512mb sdram, 80 gig hd $1200
Alpine 5 ch amplifier $200
Alpine ERE-G180 passive EQ $200
JL Audio 12w3 sub in spare tire well enclosure $200
Pioneer 6.5” front component speakers $50
Interior:
Shadow grey interior swap from 91 mk3 $400
TRD shift knob $40
New leather shifter and e-brake boots $50
C’s JDM short throw shifter $200
JDM MK4 steering wheel $60
Suspension:
JIC FLT-A2 coilovers with 14k front springs, 10k rear $1700
Suspension Techniques sway bars $249
Strut tower bar $30
Wheels/Tires:
5Zigen FN01R-C wheels, silver, 17x9 and 17x10, +35mm offset f/r
Falken RT-615 tires, 245/45/17 and 275/40/17 around $1400
Drivetrain/brakes:
4.30 LSD differential $100
TRD pressure plate, stock disk $450
89+ rear crossmember swapped in
Brembo cross drilled and slotted rear rotors $114
Wilwood 13” front rotors with Wilwood 4 pot calipers $1200
Plus at least $500 in various hoses and little custom parts for a bunch of stuff
Probably a couple hundred hours of labor not included
$1400 for the car
$18979 total, and that's a conservative estimate
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
i bought a set of wheels and tires for about the amount of money into my supra.
car-900
exhaust resizing-100
parts and labor for suspention-850
intake-35
the summer rims and tires on my DD cost 1800, but are well worth it
ChadMKIII
Yup, Thats The G/F
Jul 14, 2006
369
Bay Area, Ca
3000 - Car
2500 - BHG + ARP bolts :cry:
300 - Head Unit, front speakers
200 - Apexi Intake + Custom Cold Air Fabbing
180 - Subwoofer & Amp (not installed yet, & new box still to be made)
120 - Blitz Turbo Timer
25 - Dr. Jonez Manual Boost Controller
Total ~ 6400 (there's some other miscellaneous stuff too)
Ouch. I never thought I'd put that much money into it (and its not anything like what most of you guys have...)
OneJArpus
2,798
This is just in the past year. It will be 1 YEAR Exactly on Feb 4th 2007. This includes parts for both cars, the price of both cars, parts gathered so far! More to come. Does not include oil change or insurance costs.
HTML:
Hella H4 E-Codes	                $100.00
Euro Turn Signals	                $110.00
JDM Rain Guards	                $63.00
JDM Bubble Side Markers	   $35.00
Clear Hatch Sun Visor	   $130.00
APEXi Power Intake	   $130.00
HPF Goliath Exhaust	   $625.00
1J MOTOR SET/CLIP	   $2,200
Hydro Fan Setup	                $200
2J THROTTLE	                $44.95
1J TIMING BELT	                FREE
1JZ Engine gasket set	   $175.00
SPEEDO CABLE (upper)	   $72.90
SPEEDO CABLE (lower)	   $9.86
1J SENDER ADAPTOR	   $20
P/STEERING LINE & BANJO       $100
WIRING HARNESS PNP UNIT	   $110
CLUTCH	                             $510
Koyo Radiator	                $390
1J Custom Mounts (BIC)	   $175.00
IC PIPING & FMIC	                $405.00
Shipping estimated on the above parts	$1,000.00
Price of 88 Supra project	   $700
Price of 89 Turbo DD	   $1,500
Price of rebuilt LSD	                $250
Price of 89 Auto rad installed   $250
Price to repair brakes	   $300
Price to repair hoses	   $150
Price to repair wheel bearing	   $150
Price to repair tie rod end	   $50
1J Down pipe	                $235
test pipe	                             $60
Total So far	                $10,250.71
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
I got my car for free... I got all my mods for free... I got all the machine work for free... And Everything else I do to the car will be free...
*falls over*
jz*supra
164
Lethbridge, Alberta
I bought my car for $5000. Put a 1000 buks into it before it came over from japan. Then about another 1000 this summer.
Winter rebuild estimate over 10000.
then it will need paint, suspension, minor interior and small touch ups.
Originaly planned to spend alot more, but now im thinkin about moving out with my girlfriend.
That and im still only 17 :icon_razz
Just sum advice for any younger guys out there.
Working construction is alot better than anyone will tell you. Im 17, going to highschool and can still make 40G a year:icon_razz Once i graduate i will be looking at 70G a year, with benefits :biglaugh:
Im almost a fourth year apprentice soon to be making $20/hour and more while going to highschool. I listen to all my friends talk about getting 7 buks an hour and 200 buks a pay chek. 2 weeks for them is 1 day of work for me. I love my job, love my car, love my girl, and got enough $ to do what i want.:biglaugh:
kwnate said:
bought mine for 2,000. I probably doubled that in mods so I'd say around 4k.
I would have thought you'd spent about $4500.00 on upgrades, bringing your total to $6500.00, but I guess I was giving your car too much credit............;)
Now that I see both sigs, yours does look better.....................damnit man!!!!!!!
QWIKSTRIKE
475rwhp459torq an climbin
Apr 3, 2005
1,172
Some where out there
Supracentral said:
Never EVER add up what it costs to build a car. EVER.
As a matter of fact, I now need to go look at naked women or something so I'll stop adding shit up in my head.
Bastard...
LOL....agreed I am not even going to try to figure this one out. Years ago I stopped atthe 15k mark of trying to fiure out the amount. I prolly spent over 5k in the last 6 months in upgrades.
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
Nate you got screwed if you payed 2k for that mess of a car.....:icon_bigg
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
Got my 89 Turbo for trade. Traded a 1996 Conversion Van for it. :)
Spent about 1500.00 in repairs and upgrades -
Then got a BHG
(some of the stuff that was suposed to be done by prev owner was not :( )
About to spend about 10k total. I agree with someone that said now I dont feel that bad spending 10, alot of you have spent so much more then that.
