600rwhp was my goal.integra08;1337818 said:Whats the hp goal on this one?
funky_monkey58;1344999 said:But now that my engine is toast the new goal is back running this summer and to max out my turbo.
So whatever a gt4088 will push out under full boost we will find out.:3d_frown:
:cry:92nsx;1345487 said:Andgoes the next engine without a tune![]()
funky_monkey58;1345504 said::cry:The next one will be dyno break in and tune.
I am having one built all I need the block my head is already good to go.92nsx;1345529 said:That is a good thing to read. You going to have one built or plan on buying one already built?
Give me enough $$$$ you can have mine plus a shell![]()
Not cool at all.LilMissMkIII;1347993 said:Not cool!!!!!!!
I have heard this is not an uncommon event.IJ.;1348004 said:Sean: There are people building these engines that just shouldn't....
Thanks man I appreciate the kind words.SURUKO;1348031 said:man its really bad what hapened to your supra....:cry: but now you can be sure you build the engine your way and know what to expected from it ....:naughty:good luck wish all turn good again man...:icon_bigg
Toy-Rific;1351052 said:Sean, Tell me about it! I have the 3000 down again. Just too much oil going up in smoke. Had to fix the exhaust leak on the back turbo and stop the back turbo from burning any more of the fire wall,so is that how that name came about? anyway I pulled the heads to check the seal's hopping that would be the easy way to stop the oil from going into the exhaust, but no so.
Turns out the pistons, all 6 of them were under size by .006in. Also turns out it was my problem for not having the engine builder catch that mistake. The manufacture claimed that some times small mistakes do get past there quality control and they were will to replace my set with a new set of pistons for my motor. I said I already have new ones from a different manufacture. I asked for my money back and there policy is a replacement and not refunds.
I am finding out that at my age the learning curve is more of a down hill slide than a curve. Should I change over to a Toyota where every thing looks easier??
