finnaly started...project wanna go fast
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
7-27-08 update page 11-She is running!
3-31-08 update page 7! (machine work done-RSR in)
12-24-07 update page 2!
a lil history first... got the car back in may for 800...ran but had a blown turbo and shitloads of boost leaks...put a new turbo and drove it for a while till winter came...never had the tiem to work on it yet untill recently me and my da got the garage finished.wanted to wait till christmass before i spend any money...i have however bagan to pull the motor.its really not as easy when you spend all day working on cars fo a living come home from an hour drive to work on this lol...about 3 hrs worth of work here.
UGLY ass maroon
xmas gift to the sup :thumbup: to drifmotion
THE PLAN:
finish pulling the motor...hopefully christmass day..all i got left is driveshaft, motor/trans mount, exhaust and fuel feed line...i think that should be it.after the motor is out i'm opening it up to check it out and off it goes to the machine shop...in the mean time i clean and paint engine bay.also need to repair rust under battery tray...
Heres what im going for in order i want them done:
Engine:-
-oem gasket kit:bought
ARP main, head studs and rod bolts- recieved
Aisin oil pump-received
OEM water pump/ t-belt-received
Clevite bearings-bought
topline rings-bought not sure if i'm using them
new freeze plugs-bought
waiting for freeze plugs to get here so i can send the block to the machine shop...i have everything i need for the motor i just need to make sure what size mhg i'm gonna use after machining.Probe pistons are sold!
As of right now i'm planning on going map-ecu route.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i'd rather have one pretty clean,not running-then one running,but beat up.my nephew is looking for one,now that he has seen there potential first hand.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
yes mine was unfortunate to have a really bad owner for 3 months.he bought the car turned the boost to 14 psi and beat the shit outta of it till the egr cooler gasket blew and it sounded like the car had rod knock...so he thought the engine was toast and sold it to me for 800 lol...he bought for like 3500 3 months earlier i have the receipt somewhere haha...dumbass
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Looks like ya got a little bit ahead of you, good to know you'll be taking your time. Body doesn't look like it's in too bad of shape.
As for the MHG, decide after the machine shop is done machining the block and head, ask how much they took off of both and do the math to figure out which size headgasket you'll need.
Also, make sure they machine the block with the lower timing cover on, a lot of shops do not do this and will result in the headgasket not seating properly.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
thanks for the info!this is teh reason i love this site...
also, the body looks decent in the pics, but the car has been rear ended before (r-title) and tehy did a bondo job on it...not the greatest and rust is bubbling the paint on the quarters...
Sounds like you've got a long road ahead of yourself, but you can only drive them one mile at a time. Make yourself a list and slowly mark them off one at a time. If you don't, then you may get overwhelmed with how much stuff you have to do. Make it a bunch of little projects and you'll feel like you've accomplished something instead of looking at the big picture and thinking you'll never get it done. Good luck, and Merry Christmas.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
merry christmass to you!!i love your supra even if its blue:icon_bigg
taking stuff apart and putting it back together is not the biggest of my worries...i do it at work everyday!
my biggest worry is the fabrication stuff...i've never really welded before.that is gonna be my biggest challenge...i decided to start off "easy" and get the motor done...i just need to figure out all the RIGHT parts i need!!!not as easy as walking into the parts room and order a gasket kit and two rods and pistons for a 3.3 caravan motor...
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
12-24-07 update
Got the motor out today!!!woot woot!!!
pics for your pleasure i guess
when you are alone in the house make sure the damn car is secure if you are working under it!!!!
pb&j break
this is my holy shit face
lesson learned...take the damn harness out off the fire wall not the engine!!!!makes removal a lil easier but i still dont think its worth it!!
wish i only had this much wheel gap...
rust i was talking about
getting there...
finaly
kotu100
1,899
Easton, Ma
nice, looks like you got a lot of work done. looks like i wasted 45mins taking the ac compressor off... :(. that rust doesnt look TOO bad, lil bit of grinding will let you know if it needs to be sectioned. this isnt as hard as it sounds espcially for such a small spot., time for some simple green in that engine bay, should clean up nice.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
haha why did you remove your a/c?i'm completely eliminating the a/c systme...the car IS targa after all:naughty:
also i'm planning on removing everything from the engine bay to degrease and paint it black...once the car is done (engine, supension, interior,)i'll take it to the body shop and they can paint it for me:icon_bigg i mite do the body work myself, but i'm to anal it would take me years just to make sure everything is straight lol
kotu100
1,899
Easton, Ma
i took it off cuz a thread on here told me to, " 7m removal in 49 easy steps" right now i got about 15 steps left to go but it mostly just the ground wires, and my messed up hands arent helping.
i'd say just give the body work a try, worst case the body shop will just have to fix it again which they woulda had to do in the 1st place, but u get some practice lol.
i gotta get workin on this thing asap, see if i can catch up to ya. :biglaugh:
oh and if u need any parts lemme know, i got a spare 87 sittin here.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
o ok didnt know you where removing your engine to, it tells you to remove the compressor so you dont have freon spraying in your eyes lol...mine was empy so i just disconnected the lines...and i'll ;lett you know if i need any parts THANKS!!!and yeah i'll probably do the body work....just need patiance!
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
today wasnt very productive... pushed the car out so i can clean up the garage...got the tranny seperated from the motor.not really an update just thought you might enjoy some beat up clutch pix
****~I had no part in the condition of the clucth~****
Can't see in the pics real well, but the flywheel is cracked al around.some cracks i can feel with my finger nail.i was planning on getting this resurfaced, anyone know if i still can?
camera sux, but the clucth disk is pitted, small little chunks missing...also its almost down to the rivets.
