7-27-08 update page 11-She is running!
3-31-08 update page 7! (machine work done-RSR in)
12-24-07 update page 2!
a lil history first... got the car back in may for 800...ran but had a blown turbo and shitloads of boost leaks...put a new turbo and drove it for a while till winter came...never had the tiem to work on it yet untill recently me and my da got the garage finished.wanted to wait till christmass before i spend any money...i have however bagan to pull the motor.its really not as easy when you spend all day working on cars fo a living come home from an hour drive to work on this lol...about 3 hrs worth of work here.
UGLY ass maroon
xmas gift to the sup :thumbup: to drifmotion
THE PLAN:
finish pulling the motor...hopefully christmass day..all i got left is driveshaft, motor/trans mount, exhaust and fuel feed line...i think that should be it.after the motor is out i'm opening it up to check it out and off it goes to the machine shop...in the mean time i clean and paint engine bay.also need to repair rust under battery tray...
Heres what im going for in order i want them done:
Engine:-
-oem gasket kit:bought
ARP main, head studs and rod bolts- recieved
Aisin oil pump-received
OEM water pump/ t-belt-received
Clevite bearings-bought
topline rings-bought not sure if i'm using them
new freeze plugs-bought
waiting for freeze plugs to get here so i can send the block to the machine shop...i have everything i need for the motor i just need to make sure what size mhg i'm gonna use after machining.Probe pistons are sold!
As of right now i'm planning on going map-ecu route.
UGLY ass maroon
THE PLAN:
Engine:-
