FINALLY SOME TIME TO WORK ON MY BABY!
I know it doesn't seem like much, but I finally swapped out my wiper linkage, put the new motor in, got the ABS actuator back in, and finished *all* of the wiring on the passenger side of the body harness!
here's the wiring for the A/C aux fan, the horns, and that sensor thing for the hood:
Gotta look up the wiring diagram of what wire does what, so that I may do my re-wire of the new Hella 90/130 watt headlights.
Slowly getting the driver's side wiring complete. As you can see, I need to fix that main power wire from the battery, as well as my altenator harness pigtail.
New N/A hatch with ZERO rust that I finally got around to picking up from Jeff.
So tomorrow, I'll be finishing the driver's side body wiring harness, doing my re-wire of the headlights, and hopefully completing my electrical fun.
Then I'm replacing my lower ball joints, rack and pinion, and outer tie-rod ends.
After that, I'm going to sit down and start going through the TEC-2 harness assembly I have here (which I'll snap a pic of tomorrow for you all
