Just ordered the following:
33365-35030 (1) Shift Hub Key for #1 Clutch Hub Assembly
33371-35020 (1) Clutch Hub #1 Snap Ring (holds the assembly together)
90520-38012 (1) Input Shaft Bearing Snap Ring (2.3mm - measured 2.286mm)
90520-88001 (1) Input Shaft Bearing Snap Ring (big one around bearing)
90520-56002 (1) Counter Gear Snap Ring (on the bearing)
90520-23041 (1) Counter Gear Snap Ring (2.2mm - measured 2.25mm)
90520-30020 (1) Output Shaft Rear Snap Ring (2.10mm - measured 2.05mm)
90201-08020 (1) Washer for Oil Pump Driveshaft
90201-10054 (2) Washer for Camshaft
90507-18001 (1) Timing Belt Tensioner Spring
