Quick update-put the new wastegate in yesterday and cranked the boost back up but she'd only hit about 17psi with a really bad sputter while boost was building. Been on that train before, busted out the boost leak tester and it looks like I've killed another elbow on the turbo outlet
This'll be #2 I think, lasted about 5k with heat wrap on the manifold and it.
I ordered an aramid reinforced hose from HoseTechniques this morning that's rated to 500F (been using siliconeintakes.com couplers that are only rated to 330F) so hopefully it'll last a little longer. I'll probably eventually just have an elbow welded to my compressor housing, but this turbo has unfortunately developed some shaft play in the 10k miles I've used it so I don't think it's worth the $$ until I have it rebuilt or replace it down the road, plus the PO of the turbo rounded off the head of the housing bolt behind the oil drain so I can't get the comp housing off...
Front end is all done and aligned, feels much better with new BJs and TREs! Also got my Lotek pod installed, looks much better than the universal one that was on there before.
