Tested the brakes and swaybars tonight, wow what a difference! Brakes need a lil more bleeding but it stops like crazy and I couldn't get 'em to fade. Swaybars made a huge difference too, I took one of the back roads I run a decent amount and looked down at one point and was doing 80 in a curve, wouldn't have known it if I hadn't have looked...
Car is running alot better too, been tweaking the AFC and I think I've pulled some mo power out. Back end goes sideways when boost hits at 12psi in second:evil2: Still a little breakup from 5500 up (plugs regapped to .022), not sure what to try next, maybe some new plug wires. Also going to redo the CPS wiring and check out all of my coil packs again.
