Good job man. Get some engine harness loom and strip the old one and put some new loom on there. It really changed the engine bay. I did it for mine and looks really good. You can see it in my build thread.
Supra28;1539012 said:Congrats on getting the car back together man, been following your build, but held back on posting lol.
Something about that bay I really like, haven't quite figured it out yet. :thumbup:
CajunKenny;1539081 said:Thanks for the compliments! It's funny you mentioned the alternator. Out of this whole build......that's my favorite accomplishment!![]()
CajunKenny;1538911 said:Yeah, it was a pain; but, I got it fixed and didn't need to use any RTV!
Ok, well she backed out of the garage and made it for a short cruise. And she did this ALL under her own power! :biglaugh:
Here's a shot of her all buttoned up.
And a little bit tighter view of the Intake and IC Pipe...
SupraRon;1539082 said:Meant to ask you Ken, do you have to mask the alternator before spraying it? Or can you just shoot away?
92nsx;1539176 said:Careful with that lip I had the exact same one and well let just say the ending or it wasn't good. :cry: Being around 2 1/2" tall she hangs low and tends to hit everything. Keep your eyes out for pot holes, and drive slow in & out of gas stations along with driveways.
crisp;1539209 said:Thought I'd pull up those shots for a second look! Nice and clean... like the contrasty shots, too!
On that T-housing... I've had recurrent issues with blowing the ring gasket (usually Felpro's) when the T-stat's sharp edge cuts the rubber from the pressure. I've started "smoothing" the T-stat perimeter (sharp stamped edge) and popping out the "tit" to allow SOME flow all the time. I wonder if having "sanded" the housing face smooth took some material off mine and made it a tight squish on the gasket?
Anyway... nice to see you are almost a DAILY DRIVER status! WOOT!
-crisp
carter;1539242 said:Congrats man,
Love the engine bay man
CajunKenny;1539343 said:I guess I should've taken pics of this process... What I did was split the case and shoved/worked index cards in between the case and the windings. I think business cards would work better. I then covered everything else with paper towels and masking tape. Then painted it. The last thing I did, was polished the rear cover on the alternator. That part was REALLY easy. I sanded it with 1500 grit, then again with 2000 grit, then hit it with polish. Polishing that part only took around 10 minutes to do.
vIetDrIfTeR;1540295 said:nice niceee
thedave925;1540467 said:Beautiful work and well thought out vision made reality, its been a treat to read your build thread!
