Yellow13 - nope, the house deal i had in place fell through, the landlord kept the deposit and it all went pete tong. Had to quickly find another place, eat into the 1JZ fundage to put down a deposit and i have to move this thursday :/
3p141592654 said:Is there an online source for tinted display covers? Also, CRE, did you use an online PCB house to make your circuit board (e.g. pcbexpress.com)?
3p141592654 said:The latter, I'm looking at a tinted cover for displays, rather than changing the color. I think just a piece of grey tinted plastic would do, cut to shape and glued on the back of a cutout.
I'm cooking up a project that will require SMD components, so I am leaning towards a commercial PCB. I think I can do it with protoboards, but things would be simpler with plated vias. PCBexpress will do a two layer board for $60 (qty 2 boards) so that's not too bad.
3p141592654 said:The window tinit is a great idea, but for my app, I have a hole, so will need to use something more rigid than film. Maybe a piece of plexiglass covered with the tint would work.
xrated89 said:do you have a pic of the new color on your turn signal indicators? I want mine red and don't know how to do it : )
jdub said:I put blue LEDs in my turn signals; no change to the stock plastic color. They shine blue when actuated.
CRE said:Oh, it'll work, I've tried it out too. There's a color shift to it that I didn't like, but yeah, it works. The color they shifted to when I tried it was something of a sea green... did yours turn out more vivid?
jdub said:Yep...vivid blue...just like the headlight bright indicator. Looks good![]()
CRE said:Excellent, using the common 4 LED wedge replacement, I presume? This is all academic for me, as I mentiond mine are white.
xrated89 said:hye cre any news about the clock or whatever you had planned to replace it?
tea_mkIII said:hey cre not sure if your even wanting to but are you doing custom cc temp displays for a price or no? if you are, i think id want a blue one...jw? if not its no problem thanks man
Tommy
