arizzle's 92 teal project2!
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
well i painted the block this weekend, it showed up flat black! i thought it was going to be shiny. did almost 4 coats but it looks really nice esp when im done polishing a few parts.
Green7mgte
65
North Canton, Ohio, United States
nice. the teal 7mgte's are nice (i own one) rare paint. I got the targa top and leather seats. but I must say your car looks nicer on the outside then mine does. :( just woundering what mods besides the exhaust and downpipe did you put in? also im getting my body repainted you think the color is going to be highly expensive? I hope not, I don't have any paint buddys in my town :(
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
hey thanks man, mines in average shape theres alot of flaw, if you saw the pictures in the beginning i have a few pictures of the dmg when i got it.
as for mods im building the motor a few pages back.
but the motor is def not stock. :evil2:
Green7mgte
65
right on. well lets see some more updates.. (wishes it was spring) I cant do crap to my car till the weather changes.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
well got my bearings and started to work!!!
lastnight i got the crank in and the arp studs, and the piston and rods.
the arp mainstuds dont really give you a set of where the studs go cause they also come with 2 bolts which should go on cap## as its for the oil pump line to clear! i figured that out at the end of the night when i decided to put the oil pump in!!!
all lubed up got a bit crazy with the moly lube!
all together and the oil pump installed.
timing cover mocked up still have to replace the mainseals,
next up is putting the head on either tonight or tomorrow afterwork!
BrandonW
1,300
N.J.
yeah man nice, just got the head on mine this week with the hks stopper gasket and arp studs torqued to 80ft/lbs as per the the instruction in the box since they were new
guess you couldn't get any teal paint for the block in time lol
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
well the motors probably not going in for a while, so im going to see if i can get it before i put it in.
ninja6o4
57
Surrey, BC
omg really? i'm glad you're enjoying the car, no way I would have the patience to fix a BHG if it took this long! :p heh j/k
good work man, i am really glad you're giving it the attention it deserves.. i'll check back in later when you've decided to go 1J...
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
yes really! it had a second BHG! lol
thanks i try my best all thats left after this is body work :)
redma70;1491707 said:
Coming along good!!!
I really wish I had the money for my bearings right now :-( lol Its the only thing holding me back
thanks man so is your! yeah i ordered mine 2-3 weeks ago i dont remember thats how long it was! lol and i got a smokin deal! 90cnd at lordco so i could let it up!
slightly_red_MA70
Holy S*** I own a Racecar
Jan 24, 2009
417
Canada
WHAT!!!!! I'm going to lordco lol
EDIT:Nevermind :-( best I can get is $190 lol
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
haha serious! my guy can probably get it for 100, ill ask him tomorrow but its a special order.
update:
i got to work again today got some hours on the motor ran into a few problems, like i forgot to put the studs in before the washer. mount the head and didnt have a proper sockey my short 12pt 14mm was way to short.
also mounted the fuel rail, heads studs on but not torqued down yet, cleaned the cooling hardlines, put the turbo lines, just needs a good cleaning.
gte cams are in until i find a cressida throttle links/ and bracket cause it hits the pvc line on the cover, also have to polish up the front timing cover and put in a oem timing belt for now until i can afford a greddy t-belt and titan cam gears.
heres a few pictures from earlier.
BrandonW
1,300
N.J.
looks good, your about at the same stage as me
i wanted to replace that hose with the braded hose like that, what do you have to do? (that hose that feeds oil from the head to the block or vise versa)
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
nice! yeah im still far! :icon_evil
umm well the previous owner got it done, the stock adapters are actually removable! and also he cut the valve cover adapter when it was off and welded a AN fitting. im not sure on the size but it would be pretty simple since i now know those adapters come off!:biglaugh:
BrandonW
1,300
N.J.
yeah it seem like a better thing to do then that rubber hose, plus that looks better i gotta look into that
(oh and you have your valve covers on and i don't but i have my oil pan on and you don't lol)
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
yeah looks a 100x better, no the valve cover was for test fitting the AN line, also i tried putting the NA covers and see if the throttle links would work but nope. i should have it all torqued down tomorrow and the cams and a timing belt on and possibly the oil pan.:love:
slightly_red_MA70
Jan 24, 2009
417
Canada
Yeah let me know, cause right now the best ive found is 100 american plus shipping.
And the motor is looking good! I also want to do a braided oil line like that on mine.
HKS_TRD
998
Australia
Is the braided line -12 or -16
Also have you test fitted to see if it will clear the lower runners and stock alternator bracket and alternator in stock location or are you running a different setup?
Just curious as I have been tinkering with the hose in this area and keen to see what the possibilities are
