arizzle's 92 teal project2!
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
heres a few more pictures.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
tekdeus;1477449 said:
Hope your garage is heated, it's cold out! How come your oil feed line wraps around the turbine like that? You don't want the rubber inside that line getting hot and degrading/clogging the line.
unfortunately the garage isnt heated:cry:, yeah we did as much work as we could with the doors closed and a mini heater on to keep a bit of heat in,
as for the oil feed, it doesnt wrap around the turbine theres just alot of slack that i just wrapped it around, it stays on the outside of the turbo cause i didnt want to run it through the manifold.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
update!
picked up a few things and had cancelled my mainstuds and going to be picking up a set locally at mopac!
also ordered a full set of clevit bearings!
shimmed the oil pump 3mm
the block/ crank is at the machine shop getting jet washed / cleaned i should have it by mid this week!
also started polishing the valve covers,turbo houseing and also heat wrapped my manifold/ DP!!
will get pictures up soon!
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
well update..
i got motor lastnight!!!!!
so i got it on a stand taped her up and sprayd 2 coats of primer!
its a bit blurry but its a AN fitting :)
I'll be putting a few coats of paint tonight and then ill be putting it back together. but the only issue is my clevit bearing havent come in yet. i should be in a week. i will be picking up a set of arp mains tomorrow :)
BrandonW
1,300
N.J.
nice, i went with clevit bearings also
i kind of wish i had painted my block the color of that primer you used or some sort of silver but i left it unpainted oh well
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
nice!!
yeah its just primer i decided to just keep it black, its like a flat black ;) i was going to do red but red and teal kind of clash haha!
BrandonW
1,300
N.J.
arizzle;1486024 said:
nice!!
haha you should have painted it teal
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
Enraged;1486124 said:
if you paint it black, you wont see the oil leaks :) could be good or bad.
hah yeha i know, but i dunno what color i should paint it i was thinking silver. but well have to see i just want a clean / stock looking bay.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
hahah yeah i know i was thinking red thought! no joke!
but yeah i think ill see if i can get teal paint for it! :) but i think black will also be sexy!
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
teal would be wicked. most automotive paint shops can put paint into a spraybomb for you, so all you need to do is bring in the color code for your car.
