Dammit... I had a long ass post on the compilation of all my research efforts regarding the engine rebuild... and it disappeared when SM went down earlier. I will try to rewrite what I can remember. At the end however I stated that I may just do a simple rebuild with crank work since the rest of the engine should be ok. and I'm too poor to rebuild it the way I want (to support well over 600hp)
Please feel free to add anything I missed
- Block examined for general health and cleaned
- Crank inspected, I did have rod knock after all, if it passes, then balanced at high rpm's and the journals either hard chromed or micro polished or both
- Forged rods (I'm going with eagle)
- Forged pistons (I want longevity and may try to see how much coating costs) I may just stay stock for now since I'm only using an upgraded CT for now OR I'll just get the CP or JE pistons (block machined to match each piston if I go with new ones)
- Bearing... need to find them NDC bearings since clevites apparently no longer exist
- MHG (goes without saying, but I added it just in case someone think I forgot) HKS stopper
- All ARP hardware
- Block decked with rear timing cover
- new freeze plugs
- upgraded oil pump (already ordered)
- upgraded oil pan with baffles (already ordered)
- new oil shaft bearings
- upgraded oil pump driveshaft retention plate
- oil squirter delete? (if this is recommended, then my 6 new squirters will be on sale after the build)
- Head polished for MHG
I am avoiding any major headwork unless it is completely necessary
Mods to support:
- 57 trim CT 26 with exhaust clip by Albert (on its way to him right now)
- 550cc plug n play FIC injectors from Suprasport
- Lexus AFM (already have)
- BIC DDP/test pipe/tanabe (already have)
- Walbro with 12v mod
- High Stall torque converter
- Modified valve body with shimmed accumulators
That's all I can think of right now, feel free to comment, the more feedback the better I feel about undertaking my first engine rebuild evar.
- All ARP hardware
- new freeze plugs
Mods to support:
