http://www.amazon.com/Mothers-5101-Aluminum-Polish-Paste/dp/B0009H519Y/ref=pd_bxgy_hi_img_b
sorry it's mother aluminum polish... not meguiars
TBH the polish is not mandatory, you'll see once you strip the wheels, the machined face is very shiny already.
as for my daily, sorry I haven't updated the thread in a bit. I got myself a Lexus SC400 1992 with 151k miles for $3700. She runs wonderfully, but I have a CEL and the codes indicate both main o2 sensors, but after changing those out, it's still pulling the same codes, I think it may be a TPS issue which would explain my high idle. But all in all it runs good and I can focus on the Supra now.
My plans for the Supra right now are to purchase an already built 7M from a buddy for $1600. It has clevite bearings, eagle rods, stock pistons, HKS MHG, ARP bolts and a new oil pump. It also gets amazing gas mileage for a 7M, but once I pick it up... that will change. I plan on getting the DM upgraded oil pump with the ARZ oil supply tube and the upgraded oil pan for lower end upgrades. top end I think I will keep stock. I'll get some 650cc injectors, a 57, 58 or 60 trim from Albert, Lexus AFM, braided lines for the turbo oil supply, oil filter relocation, oil cooler, BIC engine mounts, upgraded alternator, and an HKS BOV.... and an AEM truboost gauge/controller. At the same time I plan on finishing building the a340e: I'll send my valve body off to Devin, my t/c to boostlogic and install a filter on my cooler lines. I also need to install my new steering rack and PS pump and inline filters for that as well. I would also love to find a fabricator to weld up my custom IC pipes. And I will need to install my walbro an do the 12v mod on it. I also have some new interior pieces coming in, so those will be installed as well. Hopefully by the end of winter I will have all this done.
