Today fitted all pistons, to my big surprise deck height is higher then my expected 0.3-0.4mm figure. Measurements are:
#1 - 0.65mm
#2 - 0.50mm
#3 - 0.62mm
#4 - 0.57mm
#5 - 0.60mm
#6 - 0.63mm
I have 0.060' head gasket, if I knew I would have ordered 0.065'
My smallest piston to head distance will be 0.87mm (0.0343') on #1. I think I should be just fine, though having PTH distance 1.0mm would be more comfortable. Some V8 guys run it 0.030' at 6.0-6.5K rpm. I want 7500 rpm redline, but my pistons are lighter then V8 pistons and don't stretch rods as much.
Static CR will be average 8.8:1
I wanted to fit front and rear covers on RTV but decided not to use it. Can be big problem in the future to separate covers from the block.
Turning torque of rotating assembly 9 Nm = 7 lb-ft
