Last few days was busy with multiple small, and not so small things.
I removed compressor housing to measure compressor wheel. To my surprise it is 80mm wheel, not 78mm I ordered. In 2009 Turbonetics discontinued T78, so they sent me 80mm turbo, 1200hp :icon_bigg.
Installed Craig Davis el. water pump into the lower radiator hose. It is ~2kg lighter then my previous Meziere and flows more. I cut off mechanical water pump housing from timing belt cover.
Rerouted heater bypass hose (I have no heater) to upper radiator hose. Should have to improve coolant flow through the rear part of the cylinder head
Prepared flange to pressure test Wilson overpressure valve - even with fully tightened springs it doesn't hold even 0.5bar pressure. It is N/A engines valve, though it is listed on their site for boosted applications. I have to find stiffer springs to make it work
Turned upside down intercooler, my friend fabricator modified inlet tank. Now IC pipes will be very short
![](http://img386.imageshack.us/img386/6048/80mmcompessorinducer.th.jpg)
![](http://img142.imageshack.us/img142/7569/craigdavisewp01.th.jpg)
![](http://img181.imageshack.us/img181/2637/cylinderheadcoolingretu.th.jpg)
![](http://img142.imageshack.us/img142/7134/wilsonmanifoldpessuerel.th.jpg)
![](http://img197.imageshack.us/img197/7526/intercooler01.th.jpg)
