Today I finished the fuel lines and mounted the AFPR. No pic as it is pretty standard.
Also put the harness back on... there are lists already from others about what needs to be done to the 7M harness, but here is what I did.
Wires that now run over the cams to the exhaust side...
Alternator - used 2J plug and joined it to the 7M wiring. 2x 10 gauge black wires are the same. The other 3 wires are the same color too, so I have them wired up the same. We will see if that is right when I crank it.
CPS - No change.
O2 sensor - No change
AFM - No change
Wires on the intake side...
ECU temp - Shortened wire and it is located under the #2 runner
Temp gauge sender - Shortened wire it is next to ^^^
Oil pressure sender - I used a short braided wire from Driftmotion out of the stock 2J oil pressure sender. I put a T fitting on with the 7M sender on the top. I ran my turbo feed from the other port. Shortened the wire and it sits above the A/C compressor now.
TPS - Extended wires to reach.
ISC - Extended wires to reach.
Coil pack - Extended to reach my coils on the strut tower.
Injectors - I wired in my new clips for my 550's.
Knock sensors - Used 7M sensors with rewired USB cable.
Starter - Used 7M starter so no wiring changes.
All the wiring going to the fuse box area is unchanged....
That is it I think. All the other crap is gone, vsv's cold start inj etc..not using any of them.......
Here's a couple of pics.. Kinda messy but this was before I tied it all down etc..
