Looks like it IS supposed to be connected directly to the battery via relay. I dont know if it will make a difference or not.... I connected my EMS power to the EFI relay behind the battery. The AEM is kind of wierd though.
The switched 12 v goes into the AEM from the key, and the AEM sends a signal to the relay to open and give it its primary 12v source to run everything. In a sense, it turns on its own relay.
Yours is a bit different though. I guess you could use your AC relay run direct from the battery for the WB but I dont know if it will make a difference. I would just make sure that your relay is pulling direct from the battery. The EFI relay would be a good choice.
