LOL, yes I am. I love that smiley.
I ran the turbo oil feed line off a sandwich adapter plate, around the back of the engine (over the bellhousing), and around to the turbo.
The BIC motormounts left me a lot of room between the engine and the firewall, a lot more than the 7M so I really doubt there will be a problem with pinching.
You can also run a line over the valvecovers, I've seen a few people do that as well.
ATP Turbo has a great selection of legnths for custom feed and return oil lines, that the route I took. Jon of MDC motorsports is also a great go-to guy when it comes to these custom lines.
I will say that the drain is quite difficult to route if you're using an ebay manifold, if you're going with -10 AN (I'd recommend it), then you should definately look into getting at least a couple of the swivel adapters (90* and 45*) they're a big help.
