I probably should have mentioned the BOV is used. It's off my parts car. If you need anything off the car let me know.
Grandavi;1147475 said:On a second note... does buying from forum related dealers help out the forums at all? Or is it just an informational thing.. like... "you can get them from here!"
Just looking at helping the forums stay alive (as this may be a lot of volunteer work directly and indirectly, but there is a price tag to having a website)
Poodles;1147512 said:That shiney cover for the spark plug galley won't seal as well as the stock unit. It's considered a gasket and as such it wears out an needs to be replaced (don't overtorque, follow TSRM specs).
Grandavi;1146145 said:Well actually.. I think I solved my "what the hell am I buying for my Supra" portion dealing with exhaust except I haven't sourced the cat replacement (testpipe). I have seen a 3" magnacat.. which looked great except for the pricetag (which wasn't so bad at 125'ish). Seeing as the oxygen sensor is up the pipe i dont think removing it would cause any problem at all and searching on Environment Canada's web.. they have zilch on Catalytic converters so i am assuming its a provincial reg .. and I doubt its an issue. I dont have to pass any smog board and I dont have to get it checked for insurance.. so I think the testpipe will be the direction for me to go.
Grandavi;1146853 said:However... I dont think there is one "best" plug. It all depends on how you drive and what the motor is set up like. I think for my 7MGTE with just basically an upgraded intake, 3" exhaust and stock boost, the NGK's will do what I need. However, now I am a touch confused on if I should go copper or platinum. Iridium is out unless I go with it on my next change of spark plugs... but this time, I am thinking of just going with either platinum or copper..
Grandavi;1146853 said:Now.. I have to go backwards in this thread to decide which ones i go with.. and I dont think the heat range is going to matter with my setup either. Just the recommended plugs (the ones that you find in the manual) are probably sufficient and no real gains (other than perhaps less maintenance) are gonna be seen if I go with any "enhanced" solution such as Iridium.
Now... the sparkplugs are gonna be an easy choice with reading... but is there any reason why NOT to get Magnecor KV85 Spark Plug Wires for the car (besides cost perhaps.. 130.00 I think) Thats what I plan to get... as mine are oil soaked due to the MKIII issue with oil in the sparkplug galley.
Edited to add....
Okay.. reread the spark plug discussion... gonna go with NGK Coppers.. should be able to grab em from the NAPA dealer in town.
Bah... you think it would be an easy thing.. lol. I found "Spark Plug, Standard Series, Copper Core, Gap 0.043, BCPR5ES-11" at an online store (trying to source a part number... ) and they are more expensive then Iridiums.. lol.
Anyone have a Number that they would recommend? NGK site doesn't show any copper cores... (unless the "nameless" one's are coppers...)
Grandavi;1147877 said:Oh yeah... 1st stupid thing I bought for the car is the brace that goes over the top of the engine attached to the top of both struts. I have it sitting in my office with me (it's purdy) but I am thinking that is a goofy thing to put on it.. as I dont think it will actually do anything...
Rennat;1147906 said:on the note of downloading the TSRM in PDF... if you google the TSRM you can find it in several locations, and theres a site that already has it for download.
and FWIW - i run no center cover and have not had an issue at all... i can actually change my spark plugs without removing anything except for the coil pack (duh) and thats it... all you need is a swivel socket to get in the tight spots.
figgie;1147899 said:I am curious as to why you think that? (You are actually correct btw. If you do the load points, the strut towers have minimal deflection from a side to side motiona s the load is carried by both A arms. It does nothing in the MKIII supra. BUT, Looks are always part of the game)
Grandavi;1147947 said:....thinking about force vectors
figgie;1147953 said:wow,
Then you are up already on most everyone here
Correct, the force vector for the strut mounts is up and down and not side to side![]()
Poodles;1148232 said:Holy stock supra batman!
As you have the TSRM, look in the maintenence section and it tells you to retorque the subframes. Mine where VERY lose, and it make targa wobble MUCH worse if they're loose...
