IJ.;1148528 said:
Sorry Dave on this one I have to disagree.
"IF" the strut bar had 2 bolts on each end it might transfer some of the loading but they don't so "IF" there's deflection in the Tower the Strut bar is acting as a hinge and not transferring anything anywhere.
Grab a cardboard box unfold it's ends so it's an open tube, think of the lower horizontal as the front subframe the verticals as the towers and the top horizontal and the Strut Bar.
Deflect the lower corner and watch what happens....
Fold and tape one end closed and repeat, this is where the extra bolts would come in.
As designed they're nothing more than a fancy hinge that needs to be removed if you're working on the car.
I am not sure if that analogy works perfectly in this respect but I do understand what you are saying.
I know a way to find out, but I don't think Goodyear will put a Supra on their Kinematics and Compliance machine because I want to find out the measured deflections with and without a strut bar
. I was thinking of bars like the TRD one for the mk4, not the cusco or whatever 1 that mvp carries for the mk3.
One reason I think it may be more complicated than that is looking at some OEM vehicle designs, for instance the rear of the 350z has a strut/shock tower bar. By our logic that bar makes no sense, but there is someone at Nissan that knows why that bar was put there, whether for the chassis or for aesthetics is unknown but I believe that bar is only there for a engineering purpose as most customers would probably have liked to have the extra storage area.
Actually the more that I think about it I think even the strut bar acting like a hinge does help our cause. Deflections are inevitable, when a load is applied things need to move/deflect to support the load (even if the deflection cannot be seen), without the strut bar all the load is applied to the one side of the car and none of it is transferred through the top half of the engine bay - maybe in some form through the upper radiator support and the firewall but even then you still have no lateral support near the top of the tower near the same location where the load is entering the chassis.
With the Bar on the car acting as a hinge, it allows some of the load(maybe very little, maybe a decent amount (1/8-1/4) is transferred to the other side of the car. If the one tower would normally be deflected by load 1/8" without the bar, if the load is able to be slightly transferred to the other side maybe it now deflects only 3/32". In effect the bar is transferring some of the load to the other side and effectively lowering the stress in the laden side of the vehicle and therefore reducing the displacements seen by the laden tire. While cornering the Laden tire is the one you are most worried about as far as holding the correct camber etc. so that is the side you would like to reduce deflection from. The unladen side has much less force going through it as well.
Again this is only hypothetical and mostly myself thinking out loud. Depending on the quality of the strut bar, material choice (the bars spring rate ( should be very, very high, determined by young's modulus and strain data), etc. it may or may not make a difference.
To bad they don't just let anyone test things like this in a scientific manner to prove if some parts work or not. Maybe if I get a job with Goodyear next year I can somehow get my car on there to see how it performs
We are lucky enough the use the K&C machine to test our formula car and it is a very helpful tool to determine where compliance is in a suspension system.
Here is some info on the machine for anyone that is interested. It is pretty awesome to use.
http://www.abd.uk.com/categories.php?Cat=79&PageTitle=Kinematics%20& Compliance
