foreverpsycotic said:
i :love: how you think man. plus, if you have the cad files for the spacer+adaptor you could always make some money off of them.
Yeah, I have though about doing that. I actually did a CAD drawing a while back for the adapter for the W series tranny's, but the HD in the computer that it was on took a shit and I didn't have it backed up on anything. (I learned my lession after that one. everything gets backed-up on disc now.) I am still pissed about that (and it was sometime ago that it happend) cause I lost about a year or so worth of drawings for all sorts of things.
OOH speeking of that,
Ian if you are reading this, do you by chance still have the drawing that I emailed you a while back that had the W series Tranny bolt pattern that you were going to test run? (God I hope so) if so, I need to see if you could email that back to me.
The way that I was planning on doing it would not requier much of a CAD file, just the outside shape of the tranny case and the matching inside profile that would be used for the CNC programming of the laser or waterjet. Once the plate is cut on the laser or waterjet, then the plate would be clamped to a butchered R154 bellhousing and the holes drilled using the bellhousing plate as a drilling guide or even just the proper size transfer punches to mark hole center locations. All in all, there is only two critical holes and that is the two dowl pin holes. The others dont matter as long as they are close enough for the bolts to go through and thread into the trans main case, then they are fine.
Something else that would make life even easier is if we could find substantially longer dowl pins and then even those holes are no longer critical and they can be drilled slighly larger like the bolt holes. Hmmmmm, the gears are turning...
