for some reason the oil pressure stays low as in between 40psi and the tick mark below it when at idle or up to 3k rpm, i dont remember it being like this. but i havent drove it in quite some time.
and im done fighting my oil leak with the tee off the oil pressure sensor for turbo feed. decided to clean off the oil where it leaks at the fitting ad jb weld it. ive tried new fittings and pipe thread tape and pipe dope but the brass bspt will not seal to the steel line off the block. so i whipped up some jb weld and painted the seam of the threads.
oh and i ordered some fiber glass heat wrap and blanket for turbo to contain the heat in engine bay, since it melted my speedo cable
wonder if there is any damage on the inside of the firewall cuz i had noticed light smoke in the passenger side after i drove it into town, didnt know if hvac fan had pulled it into the car from the vent by windshield or if it was in car
